3579
- Mute
‎03-02-2023 05:27 AM in
Note20
Suddenly one of my contacts incoming call is blocked by phone. How to unblock?
Solved! Go to Solution.
Yamialex224
Honored Contributor
- Mute
‎03-02-2023 05:42 AM in
Note20
Samsung doesn't block calls
Your carrier does
Go to your phone and look for your block list the 3 dots and it should say block numbers check to make sure the number didn't get added there. If it isn't check with your carrier
Your carrier does
1 Reply
Yamialex224
Honored Contributor
- Mute
Note20
Your carrier does
Your carrier does
