bluetooth couldn't connect note 20 ultra 5g for wireless connection to DeX on Windows 10 PC
(Topic created: 11-29-2021 05:18 PM)
Computer Chris
Note20
A little over a month ago when DeX Windows PC S/W updated I lost the ability to wirelessly connect my Note 20 Ultra 5g to my PC. I reset the network, reset the Cache's and finally did a factory reset on the phone after backup only to come to the unfortunate conclusion that the DeX wireless platform was no longer available. I tried connecting the phone using BT to Linux Mint - no problem - unfortunately the is no DeX for Linux. Tried it with Dell XPS 8920, Dell LT G5, Windows Surface 6 Pro, all had the exact same issue leading me to think the issue was in FACT the DeX S/W.
Well... I can report that the wireless connectivity is back working again since the DeX S/W update (2.4.0.24) - I AM SUCH a happy camper again. Thank you Team DeX for FINALLY coming up with a resolution in a VERY reasonable amount of time. It works a little differently than before in that you start DeX on the phone which will then automatically launch DeX on the PC - IF, it is installed and updated on the Windows PC. I have verified that this works on the Dell systems along with the clone PC i9-9900K. Thank you - Thank you Samsung. I love my Tech stuff and DeX is the BOMB!!
sparky3
Note20
Mine won't find any devices
G35913
Note20
Aye chris... it says that I'm signed into Linux on my device which is a Samsung a21 fe g something. And simultaneously it says I'm signed into my samsaung and fe g something. And I always sign out of Linux when I can. And sometimes the **bleep** blocks the sign out option. What the **bleep**?
Computer Chris
Note20
As stated in the original post DeX is not native to Linux other than Samsung's Android for Note 8 models and newer. Not sure I follow your message very well, but, I would suggest that you make sure your updates have been applied on both ends, Android and Windows. I am currently testing DeX running on Windows through Wine for Linux. Info is a work in progress... wishing you luck on your journey.
