note 20 ultra Navigation Sensitivity
(Topic created on: 1/20/21 6:10 AM)
Mamba8
Note20
In the past prior to the Android 11 update the gesture home navigation bar settings had the ability to set the sensitivity for if you had a phone case or not. This is not the case anymore since the update and is almost impossible to function as it should without the ability to change the sensitivity. It is a nightmare. I was hoping the update this morning would have fixed this but unfortunately not. How do we get this fixed??? Thank you.
TheGalaxy
Nebula
Note20
ui 3 is about beauty not function
Note20
what's not working with the settings? you are talking about the back gesture sensitivity, right?
Mamba8
Note20
yes the Navigation bar at the bottom that takes you home and back.
JoePro91
Note20
My gestures navigation has been horrible since I joined the Android 11 Beta with my Note20 Ultra. It's so bad I was forced to go back to on screen buttons for the time being.
