note 20 ultra bluetooth connection issue with soundbar LG NB5541
(Topic created on: 2/20/21 1:56 AM)
userx981t1iv7V
Note20
My note 20 ultra isn't able to connect to the bluetooth of my soundbar LG NB5541. The soundbar is about 4 years old but is able to connect to all my other devices like my tab 4 and note 8. The Note20Ultra has never been able to connect.
Things I have tried:
1) tried the optimize the battery usage setting:
https://us.community.samsung.com/t5/Galaxy-Note-Phones/Note-20-wont-pair-with-radio-fix/td-p/1592102
2)tried to remove the device and re-add
3)tried to clear the cache
4)updated software to the latest (02/04/2021)
5)tried other devices (note 8, tab 4) and it connects no problem.
Here's a video of it
https://www.youtube.com/watch?v=1Zr4wnpWnOs
Phoenix Recycling
Note20
Hi Please check this out maybe this Helps you out with the Bluetooth issue
https://www.youtube.com/watch?v=NPMp93zD8Xs
LG details
https://www.lg.com/ca_en/support/product-help/CT30016900-20150121277698
UPDATE - Check pinned comment for Galaxy S20 Android 11 / OneUI 3.x updateJoin the Daily Android News Discussionshttps://www.youtube.com/channel/UCnowc_KHgjV...
userx981t1iv7V
Note20
also tried those solutions. doesn't work
Ekamek
Sun
Note20
Go to developer options and check Bluetooth profiles for both working phones and Note20. Also try enabling Gabeldorsche on the Note20 to see if it helps. Just suggestions, not definitive solution
userx981t1iv7V
Note20
I tried to match up the settings to my note 8, and enable gabeldorsche but it still doesn't work :(
SamsungJoJo
Note20
You can try resetting your network settings on your device to see if that helps any.
  1. From a Home screen, swipe up to access the app's screen.
  2. Navigate: Settings > General management > Reset.
  3. Tap Reset network settings.
  4. Review the info then tap Reset settings.
    Note If presented, enter the current PIN, password, or pattern.
  5. To confirm, review the info then tap Reset.
Are you able to connect any other devices to your Note 20 Ultra via Bluetooth?
useroeMXUkVlvs
Note20
Is there any update on this? Works great at home and in one vehicle but only connects briefly to a Pioneer head unit then only stays connected for calls. Very annoyed as I always stream music.
