water or dust in charging port pop up disappeared
(Topic created: 09-12-2021 04:57 PM)
Notapeach
Note20
Hello all, for the past few months I had an issue with my phone.the issue was that it said there was water in the port and wouldn't let me charge it. I cleaned it and dried it out which didn't help and, my only way to charge was to use a wireless charger. Now the warning has disappeared and I don't know why. Would it now be safe to use the charging port again or should I continue using the wireless charger to avoid any issues that may come up if I used the port?
Shell96
Cosmic Ray
Note20
That happened to me when I installed s screen protector with the kit that has a liquid in a spray bottle. When I used the squeegee to smooth out the protector I got that message. Long story short, yes and my phone had worked fine thereafter
Note20
I would say go ahead and plug in your phone an see what it does
