userhj7VIAOt9r
Battery charging is slow
JUMP TO SOLUTION
Hi my battery is taking 3 hours to charge with the same adaptive fast charger from the box. I also do not have one of those battery estimates on the notifications plane when I scroll down.
Any help would be appreciated thanks!
1 SOLUTION
Red Giant
Re: Battery charging is slow
JUMP TO SOLUTION
Hello @userhj7VIAOt9r , welcome to the community!
Have you checked to make sure that fast charging is enabled? You can do this by going to Settings>General Maintenance>Battery. Then tap the upper right hand corner for settings. In there should be a slider that will allow you to turn fast charging on and off, make sure it is enabled.
7 REPLIES 7
Red Giant
JUMP TO SOLUTION
userhj7VIAOt9r
JUMP TO SOLUTION
I think the cable was worn down. Replaced with new usb to usb c cable and works well. Still don't have charge estimator it might have been and android update killed it.
Red Giant
JUMP TO SOLUTION
@userhj7VIAOt9r
Oh, I am sorry to hear that, but glad that you were able to resolve that concern.
userenuh9qmiyy
JUMP TO SOLUTION
It's on and still slow charging.
JUMP TO SOLUTION
@userenuh9qmiyy Thank you for reaching out! Can you confirm that you are using the USB cable and charging box that originally came with the device?
Have your device experienced any liquid or physical damage to the charger port or USB cable?
userPRKfgl7DMd
JUMP TO SOLUTION
Just an FYI, if you have a case with a magnet that you would use for a car mount. If the magnet is on the case, the magnet will inhibit the fast charge and only slow charge. I dealt with a similar issue, for a couple weeks, and when I changed the phone cover without a magnet my fast charging came back.
Autokrator
Cosmic Ray
JUMP TO SOLUTION
A few months ago my fast charging suddenly stopped working for no apparent reason. I tried everything to fix it to no avail. In the end I decided to buy a new charger and that was the problem. Now my fast charging works perfectly again. Not sure what went wrong with my original charger as I looked after it as well as I possibly could have done.
