Highlighted
Current Best 6 foot USB 3 to USB C Cables for the note 8?
Does anyone know of the current best USB 3 to usb C cables that are 4 to 6 feet in length? I saw a anker braided 6 foot cable on amazon, but one reviewer found it's length was causing file transfer problems, and file corruption, also the USB C side plug is oversized for the port slightly causing issues for some people. So I'm looking for the best before spending lots of money trying on mediocre cables.
1 REPLY 1
Highlighted
Samsung Care Ambassador
Re: Current Best 6 foot USB 3 to USB C Cables for the note 8?
I as well do have a 3ft Anker Powerline+ type-c/type-c cable & tho it is built very durable and works well with fast charging/data transfer the type-c connector is rather big and can cause it to not fit with certain cases. When it comes to just best performance with charging & data transfers I find the OEM Samsung cable that came with my Note10 to be the best for me as it causes no issues and is built 100x more durable then a lightning cable ever was. If you want to go with a braided nylon cable the Amazon Basics cables are pretty good as well.
