userQ491eZsFq2
Fast charge problem Note 8 June 2019
Hello, since the last security update fast charge doesnt work on my note 8.
I m using original adapter and cable. Tried with anothet samsung chargers, nothing.
I cleaned the charging port and the cable one, still nothing.
Fast wireless charging its working.
Maybe a software problem or the charging port may be broken?
4 REPLIES 4
Re: Fast charge problem June 2019
Do you experience these symptoms if you charge your device in safe mode?
userQ491eZsFq2
Yes, still in normal charge.
I forgot to say that i factory restarted the device and still the same result.
Thank you for that information. We would recommend a service repair. Can I please have your full model number and IMEI in a private message?
userQ491eZsFq2
Sure, sent.
I wanted to know sure if it s a software problem...service rules in my country leaves me without this phone for 15 days.
