userQyThcfwOQV
Galaxy Note 8 - LED indicator
JUMP TO SOLUTION
Hi,
I have a Galaxy Note 8 and I'm using "LED indicator" by going to Settings, Display and LED Indicator. I like the red LED light when I'm charging my phone, but I don't need the blue notification light when I get a new email. Is it possible to turn off email notification light? Looks like LED indicator is all on or off.
Thanks!
1 SOLUTION
Re: Galaxy Note 8 - LED indicator
JUMP TO SOLUTION
Hello, userQyThcfwOQV. The only option available is to have the LED indicator on or off.
2 REPLIES 2
JUMP TO SOLUTION
userQyThcfwOQV
JUMP TO SOLUTION
Thank you for the quick reply. That's that I thought. Could I suggest the feature somewhere? It would be nice to have a little move control over it in the near future.
Thanks!
