userBmgHSqtmvA
How to transfer files from thumb drive to Note 8 using ctg cable
JUMP TO SOLUTION
How would you transfer files to or from a Note 8 to a thumb drive using ctg cable. Seems like phone does not recognize drive is attached
1 SOLUTION
Supernova
Re: How to transfer files from thumb drive to Note 8 using ctg cable
JUMP TO SOLUTION
Alright, thanks for specifying that.
Are you able to move it to a PC? If you can move it to a PC, you will be able to store this internally or store it on Google's Music servers.
Has anyone else run into this difficulty?
9 REPLIES 9
Supernova
JUMP TO SOLUTION
Thanks for reaching out, I can understand how frustrating this may be, especially if it has worked with previous devices.
Would you mind specifying which CTG cable you are using?
Is this a USB-C cable or are you using the USB-C to USB-A converter?
userBmgHSqtmvA
JUMP TO SOLUTION
I am using a converter on the cable, but it does seem to work with other items
Supernova
JUMP TO SOLUTION
Thanks for clarifying that, sometimes when you are using a converter from USB-A to USB-C the cable will lose some functionality.
Would you mind specifying what function you are attempting to accomplish with your CTG cable?
userBmgHSqtmvA
JUMP TO SOLUTION
I would like to transfer music files from thumb drive to phone
Supernova
JUMP TO SOLUTION
I see, thanks for that clarification!
Do you have these files stored on a computer that is on the same network as your phone?
You may want to try one of the various WiFi file transfer apps found in the Play Store.
Does anyone have any suggestions for one of these apps?
userBmgHSqtmvA
JUMP TO SOLUTION
No just have music on thumb drive
Supernova
JUMP TO SOLUTION
Supernova
JUMP TO SOLUTION
Hey, I hope this was able to help your difficulty.
If you need any further assistance, feel free to reach out to our community and we'll be happy to help!
userBmgHSqtmvA
JUMP TO SOLUTION
Yes it helped and no it didn't. I have thumb drives with files and info on that i use fairly regularly. Since I have been using this note 8 there just seems to be so many things with this i can't  do where as on my note 5everything worked very well. Seems like the upgrade is not really an upgrade after all. Wish I had my note 5 back.
