Highlighted
Incoming calls hang up current call
When I have an incoming call it hangs up current call. I need my call waiting activated but that option is not available
2 REPLIES 2
Highlighted
Re: Incoming calls hang up current call
I would recommend contacting your carrier to verify call waiting is an option with your plan.
Highlighted
Re: Re: Incoming calls hang up current call
the carrier says its samsung who needs to fix this.
