usertV9vjiglVH
Note 8 Battery
Samsung needs to fix the Note phones to make batteries easily replaceable. To replace the battery is $300 because the screen has to be replaced also. I have always had Note phones but am having second thoughts now.
2 REPLIES 2
user04nc3bJPMP
Re: Note 8 Battery
I think all cell phones should have variations that allow end user battery replacement. The number of end users that need "sealed" phone has got to be the minority, yet they win.
Samsung Care Ambassador
Re: Note 8 Battery
I believe that you only need to remove the back panel to replace a Note 8's battery. This is based off of my knowledge of a Note 9 though.
