ibenzawla
Note 8 Proximity Sensor Issue
JUMP TO SOLUTION
Hi, I have a random issue with my Note 8 proximity sensor. Sometimes the screen doesn't go dark during calls as it is supposed to. I dont have a case and the sensor area is clean. It started after the recent Oreo update. Used to sork well with no issue. The sensor itself appears to be working but just not activating during some calls. Works well sometime. I also noticed that it mostly happens when receiving calls. I have not noticed issue with outgoing calls. Weird. Its a T-Mobile USA phone but currently unlocked. I did the setting reset and wondering if a full fatory reset will help.
Any response will appreciated. Thanks!
1 SOLUTION
Toni
Re: Note 8 Proximity Sensor Issue
JUMP TO SOLUTION
THANK YOU!!!
@SamsungJace wrote:
Give this a shot;
Settings>Apps>Click on the three dots at the top right corner>Show system Apps>Device Maintenance>Storage> Clear Cache/Data
Settings>Apps>Click on the three dots at the top right corner>Show system Apps>Phone (All 3)>Storage> Clear Cache/Data
65 REPLIES 65
Supernova
JUMP TO SOLUTION
Hey, I'm sorry to see this, @ibenzawla. Would you mind providing us with some information about your device?
* Model Number
* Baseband Version (Software Information)
* Carrier
You can find this information in Settings > About Phone. Thanks!
ibenzawla
JUMP TO SOLUTION
Hi and thanks for the respose. This is the info for my Note 8:
Model: SM-N95OU
Baseband Verson: N95OUSQS4CRE1
Carrier: Originally T-Mobile but now unlocked and use on AT&T
Supernova
JUMP TO SOLUTION
Thanks so much for getting back to me with this information, @ibenzawla.
Let's try some troubleshooting, can you attempt to clear your device's cache?
1. Power off your device
2. Power it back on by holding down the Volume Up, Home/Bixby, and Power keys.
3. When you see the Android laying down, wait for 30 seconds until it boots into the Recovery Menu.
4. From here, use the volume up/down keys to highlight "Wipe Cache partition" and select it with the power key.
ibenzawla
JUMP TO SOLUTION
Thanks for the response. I did wipe the cache by following your instructions and unfortunately I am still having the same proximity sensor issue. I did a full system restore multiple times but still no luck. I tried doing a clean boot without restoring Samsung or Google and it seems to work well with no issues. The thing is though with that I am not able to access Google apps or any of the Samsung features. I started having this issue with the recent Oreo update. It used to work well with Nougat. Hopefully there will be a solution in the near future.
Red Giant
JUMP TO SOLUTION
Hello again @ibenzawla
If you have taken all those steps, than I believe the next step would be to get that device evaluated and possible repaired. The swiftest way to do that would be to reach out to us at 1 800 726 7864, or via the Samsung+ application. You can also reach out to one of the moderators here, and we will be happy to get that set up. Lastly, you can also look to see if there are any walk in repair facilities near you here.
userCC2C0QgLeN
JUMP TO SOLUTION
I'm having the same issues here after updating my Samsung galaxy note 8 how do I fix it
JUMP TO SOLUTION
Can I please get your full model number and baseband version?
userWKCLOgvFEb
JUMP TO SOLUTION
Same problem here, note8 with T-Mobile
Please help.
JUMP TO SOLUTION
@userWKCLOgvFEb Does this happen in safe mode?
