userYV73dSkqrI
Note 8 charging problem
My phone stopped charging with its charger, i tryied charging the phone with note 5 charger with same usb cable, it started charging but slow charging. I tried charging another phone with the note 8 charger to get sure if the charger is damaged , but it charges. So what may be the problem if the phone slow charging with note 5 fast charger and not charging with its own also if its not damaged.
Note : from few days i got moisture detected warning but the port was completely dry so i passed the warning by restarting the phone after plug it and warning gone. Also i checked for water damage, the stiker still white with red crosses.
2 REPLIES 2
usersgnamgXBCm
Re: Note 8 charging problem
Check the port on your phone for lint. My phone had a bunch a while ago and chargers had trouble staying in
Samsung_cClOvCU
The message said that battery is draining fast after I just charge it
