userEYuPdAwD53
Note 8 handset in call volume low
Ever since Android 9 update the in call volume is so low that it's difficult to hear even in a quiet room. Now there's no option to turn on extra volume. I've completed every troubleshooting step listed on here. Excluding repairs any other suggestions? Really wondering if this is a software thing..
9 REPLIES 9
Re: Note 8 handset in call volume low
@userEYuPdAwD53 What troubleshooting steps did you try in regards to this issue?
userEYuPdAwD53
Cleared cache on phone apps in the settings, cleared system cache, factory reset, cleaned ear piece with compressed air, etc..
Can you send me a private message using this link here? provide the following information.
  • Model number
  • IMEI number
userPO3ijPgoXY
Mine Is Doing The Exact Same Thing
userU2h11HIhEQ
I am also having this problem.  Took phone back to Verizon.  They sent me a warranty phone.  Same issue.  I am now waiting for yet another warranty phone which will probably have the same problem.  What do I do?
MrsEaves
Me too and I am now on my third replacement in a week for same issue.  I turned mono audio on in Hearing Enhancement and I can hear.
userQmLMBTgcR1
While using the phone does the volume up button not turn...
While using the phone does the volume up button not turn it up for you. If your on bluetooth or ear buds you have to give permission to allow for loud volume
userVdCzV38omK
I am also facing Same problem from last 2 months
Hey there @userVdCzV38omK,
What troubleshooting steps have you already tried?
