Highlighted
Note 8 in call volume low
JUMP TO SOLUTION
Tried clearing cache Tried factory reboot Re installed SIM card Restarted in safe mode Still no change and extremely low call volume
1 SOLUTION
Highlighted
Re: Note 8 in call volume low
JUMP TO SOLUTION
Had the same problem...the solution was quite simple for me (ymmv). Gently clean each speaker with dry paper towel repeatedly, then reset phone. Volume is acceptably loud. Why they don't have an adjustment for really loud escapes me.
131 REPLIES 131
Highlighted
Honored Contributor
JUMP TO SOLUTION
Hey Community! Anyone else seeing this problem? Anyone have a workaround? Let us know!  Smiley Happy
Highlighted
JUMP TO SOLUTION
I have started to experience the same thing. I can only hear when my phone is on speakerphone.
Highlighted
JUMP TO SOLUTION
Likewise
Highlighted
JUMP TO SOLUTION
I have the same issue with my Note 8
Highlighted
JUMP TO SOLUTION
I am having the same issue.  I have tried everything suggested in this thread and nothing works.
Highlighted
JUMP TO SOLUTION
Give this a shot;
Go to Settings>Apps>Click on the three dots at the top right corner>Show system Apps>Phone(All three)>Storage> Clear Cache/Data
Go to Settings>Apps>Click on the three dots at the top right corner>Show system Apps>Speaker detector>Storage> Clear Cache/Data
Let me know how this works for you.
Highlighted
JUMP TO SOLUTION
I cleared the Cache but whwn I went to clear the data it gave me a warning. I'm not willing to lose data that will totally mess my phone up... I never could find the speaker cache
Highlighted
JUMP TO SOLUTION
I tried doing this step and it didn't work for me until I talked to a Samsung rep and he said to do the same steps only difference was to restart the phone after you clear all the cache and data from all three or I had four phone apps on mine to clear, after the restart it worked like new again. Good luck everyone.
Highlighted
JUMP TO SOLUTION
July 9th 2019.  Just so everyone knows...... this worked!  I thought I'd have to get another phone.  Not sure how this worked but it did! :-)
