Re: Note 8 not working with some Bluetooth products.
JUMP TO SOLUTION
I got it. Had to reset my wireless speakers themselves. Holding play and volume up buttons down at same time, holding down 5 -10 seconds. Now they show up as device under bluetooth😉
user7EWvnHNOJD
JUMP TO SOLUTION
Worked for my Level Up Pro headphones. Thank you for your suggestion.
Nash_Ray
JUMP TO SOLUTION
try to reset the speakers by pressing the play/pause button for 3 seconds
userRWYgPaeISe
JUMP TO SOLUTION
This is a pretty ridiculous response from Samsung, and a bit embarrassing. Get our cars / headsets / gadgets updated to BT 5? REALLY!?!?!
I'm having this issue connecting to a device which utilizes BT 2.1 (a fitness tracker). This is an APPLIANCE, and thus there is no possibility of upgrading the radio or the firmware.
Cummon, Samsung. We all paide $1,000 for your phone. The least you can do is insure that your BT radio supports older connection and data transfer types.
useravFAPhOb7d
JUMP TO SOLUTION
I have a 2013 Camry and have already upgraded the system in my car.   Additonally, I had my cell phone carrier to send me another BRAND NEW Note 8 just to be sure.   It still does not work this is a MAJOR inconvenience!!!!!
userKd4jN0qWmO
JUMP TO SOLUTION
Lisa Whitehead, this is definitely an issue with the phone. Samsung swears that it is because the software in the vehicle does not support Bluetooth Version 5.0 however the iPhone 8 is also running Bluetooth Version 5.0 and works fine.
userKd4jN0qWmO
JUMP TO SOLUTION
JUMP TO SOLUTION
Iphone has some of the same issues as well..just so you know it's not just this device. Many variables involved to why some are working and some not..updates,connections, user errors, defects....etc.
Screenshot_20171116-185223.jpgUploaded from community android app.
userb5AEZ8QtS3
JUMP TO SOLUTION
But what am I supposed to when it doesn't pair with my $200 Sony headphones?  Headphones don't update like a car...
userb5AEZ8QtS3
JUMP TO SOLUTION
Is there any workaround yet?  Another app to allow the pairing...?
