B_Hawk
Note 8 unable to charge with Samsung charger
JUMP TO SOLUTION
I have an unusual problem that I can't wrap my brain around. My Note 8 will charge intermittently with Samsung Travel adapters. I've tried a regular charger from my S4, a fast charger from my S7 Edge, and a new fast charger that came with my Note 8. Most of the time it will not recognize the charger and other times it will start charging after connecting but disconnect after about 15 seconds. I can fast charge wirelessly with no issues. I've disabled fast charging and cleared cache with no change. I've bought numerous cables 2.0, 3.0, and "3.1" with no success.
Now for the interesting part. So far every charger I've used that's not a Samsung charger works, standard/fast charging. I can connect to my PC and charge through USB so it doesn't seem to be an issue with the port. Any ideas?
1 SOLUTION
Honored Contributor
Re: Note 8 unable to charge with Samsung charger
JUMP TO SOLUTION
In that case, definitely reach out to Samsung directly via Phone (1-800-SAMSUNG/1-800-726-7864) to set up a repair. Naturally you can also reach out to your carrier to see if they have a different option you might like more or maybe someone here in the Community has some other ideas!
7 REPLIES 7
Honored Contributor
JUMP TO SOLUTION
Hello @B_Hawk
Might I ask where and when you bought your device? Also, has it always had these charging problems or did this appear recently?
B_Hawk
JUMP TO SOLUTION
I bought this phone in January from the online Samsung Shop, so I've had it for 4 months. This issue started about a week ago when I noticed it would randomly stop charging with the provided charger while I was at work.
Honored Contributor
JUMP TO SOLUTION
Sounds like something is wrong with the device itself, since it will charge wirelessly and has the same problem no matter which wired charger you're using. Just to make sure I didn't miss something though, you've tried different outlets, wires, and plugs(wall or car), it's only the wireless one that's reliable in it's charging, correct?
B_Hawk
JUMP TO SOLUTION
I've tried different outlets. I can charge with an apple travel adapter and my fast charger in my car. The car charger does allow my phone to enable fast charging. As far as Samsung products go, the wireless charger is the only one that will charge.
Generic chargers work as well. I have a Belkin adapter that will charge. I do not have a "no name" fast charger to test if fast charging will enable.
Honored Contributor
JUMP TO SOLUTION
Well let's try some troubleshooting steps just to be sure. Just let me know how these go!
  1. Are all your Apps are up to date? You have 2 places that you need to look. Google Play store and Galaxy app store. Go to both and check My Apps. Make sure there is no app that needs updating.
  2. Is your phone OS up to date? Go to Settings, About phone and check for software update. Make sure you have the latest phone software.
  3. Clear phone cache. Instructions are here
  4. Restart your phone in Safe mode. This is just to help you isolate the issue if it is caused by 3rd party apps. Instructions are here
B_Hawk
JUMP TO SOLUTION
All apps are up to date, Google play and Samsung Apps. My OS is the latest version. I cleared the cache with no change. Safe mode and powered off completely yield the same result as previously stated.
Honored Contributor
JUMP TO SOLUTION
