Is your phone network not working too? View Post
@mare3 The carriers are working on it, and some should already be seeing improvement. They're not sa... View Post
Its me, again. SM-217M.I'm not stuck with safe mode. If I reboot the phone it does go away, it works as a temporary solution, temporary being 5... View Post
Hello Samsung users. I hope someone can help me figure out this issue. Evertime that I'm trying to upload a picture to either send as an email... View Post
Hello there,Have you checked if the apps you are trying to use to upload pictures have the right per... View Post
Please fix the screen lock pin issue, we had the option to enter pin without pressing "ok". The option was there for the 23 Ultra and all... View Post
The option goes away, but the workaround works nonetheless. You have uncheck then check the box, the... View Post
So Samsung you guys have tried with 2 updates to fix the issue for us but it looks like it didn't work. I'm still having the same issue and it... View Post
How can I delete my notifications that are blocked. View Post
Could you clarify which notifications you're referring to? If they're blocked, how are you receiving... View Post
I have Gallery 15.1.03.5 & when I'm editing a photo, go to sticker, custom stickers, add, picker the transparent pgn that I want to use. It... View Post
I updated the last version of Samsung update, and the new emojis comparing with the last update it is so bad! 👎🏽 View Post
Is there a way to change the background screen color of the notification panel? If so how? Any help is appreciated. Thanks View Post
Hello,If you want to learn more about GoodLuck, watch the next video:https://youtu.be/ECOvFJMIsNk?si... View Post
User | Likes Count |
11992 | |
4795 | |
2468 | |
2397 | |
2252 |
