ZainAslam
S8/NOTE8 battery issues
JUMP TO SOLUTION
Hello i have note8 ithink i have battery issue using facebook it drops 1% every 4 or 5 minutes and using tiktok it drop 1% every 3 minutes playing games it drop 1% every 2.5 or 3 minutes i monitor my battery using accubattery check my battry life is normal or not?? And sorry for my bad english😂
1 SOLUTION
Samsung_KSIYpoW
Re: S8/NOTE8 battery issues
JUMP TO SOLUTION
Go into ur settings and find your usage access, and u will see unrestricted access promissions, u moat likely got all the apps allowed to use data and run even when closed out. That should solve ur issue after u take permissions away along with the background data permissions. Hopefully I helped and solved ur issue...
1 REPLY 1
Samsung_KSIYpoW
JUMP TO SOLUTION
