10-31-2020 11:44 AM
As of today my fast charge is not working correctly. When I plug my phone into any fast charger I get a double charge sound. It will say "fast charging", then disconnect and say "cable charging" charging again and then charge but no fast charge. I had a moisture error earlier and after drying out the port all was fine for a day or two. Then after few days, I come home plug up my phone and I get the double charge thing with no way to fix it.
I tried charging with other pair of charger and cable & even power bank (that i have been using to fast charge this phone for the last two years) but issue is still the same.
Solved! Go to Solution.
11-04-2020 11:02 AM
It honestly sounds like it may be an issue in the port, I'd recommend having it evaluated at your local walk-in service center: https://www.samsung.com/us/support/service/locations/?product=N0054182
11-04-2020 11:02 AM
