09-08-2017 11:38 AM
I just recently received my Note 8 from Verizon.
I truly love this phone except for the fact that I can't get Smart View to work. I have tried it with 2 Samsung TV's, an Amazon Fire TV, a Google Chromecast, and even a USB C to HDMI adapter. Smart View never connects and never recognized the USB adapter.
Is their a bug in the software for the phone? It is showing as fully up to date.
Solved! Go to Solution.
02-20-2018 07:34 PM - edited 02-20-2018 07:35 PM
Uninstall AD BLOCK or any popup blockers is my advice. This fixed my note 8 smart view connection immdeiately and as well I also recomend if you have a fire stick to unplug it for 30 seconds.
Thanks allot I have been working on this for 3 days lol was starting to miss my 8+ but now I realized it was actually my fault so anyone who has ad block or ad block for Samsung browser remove it and smart view will work
09-15-2017 08:48 PM
Mine did the same thing at first but I was persistent and kept trying to connect. After the tenth time or so it worked and my HDMI works as well
10-03-2018 02:58 PM
I had same problem just fixed it! Hope it works for you. Press on the smart view , but hold on to it , it takes you to a screen that tells you, about smart view, press on that, once you get there you will have a choice to [force stop], press on that. You can now exit and try your smart view now. That should do it.
09-23-2017 02:51 PM
Did you ever get yours working? Mine will not connect either. Trying to mirror my screen to a Samsung smart tv via smartview. My old note 5 still connects just fine to it.
09-25-2017 10:02 PM
Did you ever get an answer? My note 5 worked just fine.
09-29-2017 08:34 PM
10-04-2017 11:45 PM
Same here... Note 8 smart view not casting on nvidia shield or Samsung smart TV...
My daughter's s8 plus connects just fine 100% of the time... How can I fix this?
10-09-2017 09:30 AM
Add me to the list. My Note8 will not stay connected to my Samsung TV. My old Note4 works fine. Note8 disconnects after about 20-30 seconds. Is there a fix?
12-27-2017 07:10 AM
12-28-2017 05:13 AM
I've posted earlier about fixing smart view problem turning off phone visibility , well only worked for a while I think it's a glitch that samsumng has to fix I hope soon ...
