Highlighted
Smart view not working on my Note 8
JUMP TO SOLUTION
I also have the same problem with mine 08 when I first got it it worked the first couple times with some hiccups but now it just won't work at all. I won't connect to my Google Chromecast. when I open the Google Chromecast HOME app IT SAYS SCREEN MIRRORING IS NOT OPTIMIZED FOR THIS DEVICE. so I did a search for optimize devices for Google Chromecast and the Samsung Note 8 was not on the list
Highlighted
Re: Smart view not working on my Note 8
JUMP TO SOLUTION
Just restart you phone.  It works for me !
Highlighted
JUMP TO SOLUTION
Have the same problem.with mine..
Everything was working fine..until Samsung update require...so I did....the phone been **bleep** ever since..
Samsung went backwards...in my theory...
Highlighted
JUMP TO SOLUTION
Ive tried all these solutions and I cant seem to get this to work. Any new solutions?
Highlighted
JUMP TO SOLUTION
Can anyone tell me why did my screen mirroring stop working after the oreo update
Highlighted
JUMP TO SOLUTION
My Note 8 doesnt screen cast anymore either since the Oreo update.  It connects and casts for literally 2 seconds and then drops the connection and says "Smart View has stopped working."
I've tried everything in this thread, no luck.
Highlighted
JUMP TO SOLUTION
My smart view doesnt connect after the oreo update.
Highlighted
JUMP TO SOLUTION
I believe it is definitely a bug in an Android update.
 I had a Note 8 which connected fine to my TV with a Microsoft Miracast dongle until a system update after which it would not connect at all. I broke that phone and got another Note 8 and the exact same thing occurred, it connected fine until a system update and now will not connect at all.
Highlighted
JUMP TO SOLUTION
How has this bug not been fixed? This is unacceptable!  What is Samsung doing to fix?
Highlighted
JUMP TO SOLUTION
I had same problem just fixed it! Hope it works for you.  Press on the smart view , but hold on to it , it takes you to a screen that tells you, about smart view,  press on that, once you get there you will have a choice to [force stop], press on that. You can now exit and try your smart view now. That should do it.
