userYh6MdXeytk
Volume problems after update
JUMP TO SOLUTION
When im connecting to my bluetooth on my truck, the volume on media is way lower than before the update. If I turn my radio loud enough to hear it,  when I get a phone call it blows out my speakers because it's up do loud. How do i fix this?
1 SOLUTION
Re: Volume problems after update
JUMP TO SOLUTION
Try turning on your media volume sync:
  1. Open Settings.
  2. Tap Connections.
  3. Tap Bluetooth.
  4. Tap the three-dot menu icon in the top right corner of the screen.
  5. Tap Media Volume Sync.
  6. Tap the toggle switch in the top right corner of the screen to turn Media Volume Sync on and off as desired.
Try changing the call volume on the audio device in your truck to assist with the phone calls being too loud.
2 REPLIES 2
JUMP TO SOLUTION
  1. Open Settings.
  2. Tap Connections.
  3. Tap Bluetooth.
userYh6MdXeytk
JUMP TO SOLUTION
That worked perfectly, thanks.
Fyi, I only have one volume control. No separate control for calls. Thanks again
