userSDnVVa6ZtT
Why is my note 8 making a sound like im receiving a notification and i dont receive any?
JUMP TO SOLUTION
1 SOLUTION
userSDnVVa6ZtT
Re: Why is my note 8 making a sound like im receiving a notification and i dont receive any?
JUMP TO SOLUTION
No I haven't try anything yet...
9 REPLIES 9
userSDnVVa6ZtT
JUMP TO SOLUTION
All this started since the oreo update...
Honored Contributor
JUMP TO SOLUTION
Hello there, @userSDnVVa6ZtT. I'm glad you reached out here with your concern.
I certainly want to assist you further with this matter. To better do that, can the Community have the exact model number and Baseband version (both under Settings>About Device) for your device as well as your carrier and what you've already tried to fix it? Thanks!
userSDnVVa6ZtT
JUMP TO SOLUTION
N950ousqu3crc2
Sprint
Honored Contributor
JUMP TO SOLUTION
Thank you for that information. Just to be sure I don't repeat things you might have already tried, have you done any troubleshooting to fix this already?
Honored Contributor
JUMP TO SOLUTION
Just checking in to see if you still need assistance. Smiley Happy
userSDnVVa6ZtT
JUMP TO SOLUTION
Mari_K
Halo
JUMP TO SOLUTION
Hi, I don't know if you already figured out your problem, but I was having the same problem when I updated to Oreo. I have the Google messenges as my main texting app, but when I got the Oreo update, the setting for notifications from the Samsung messages app was turned on and I was receiving sound notifications without a badge or notification in panel. I turned off notifications for the Samsung messages and then went through my app list and made sure the apps I didn't want notifications for weren't switched to on after update. Some apps we're switched on, so I turned the notifications off for those again, and haven't had any problems since....so I guess it could've been ghost notifications from a different app, but it's fixed for me now.
userSDnVVa6ZtT
JUMP TO SOLUTION
Which is the samsung message app?
userSDnVVa6ZtT
JUMP TO SOLUTION
