Connection Soundbar HW - J355 to our old TV Philips 42PFL8404H/12
HI good morning,
We have recently bought a Samsung Soundbar HW-J355 to be connected to our old Philips TV.
As per what we know, ourTV has not a n optical connector to plug in the SOunbar, therefore we have used a speaker cable we had at home connect to AUX entrance and also to our AUDIO IN connector on TV,. but is doesn't work,
Can you confim if we should change any parameter in our TV?
Can you confirm exactly the type of cable we needd it works?
Your comments will be greatly appreciated.
Best regards,
1 REPLY
Re: Connection Soundbar HW - J355 to our old TV Philips 42PFL8404H/12
Thank you for reaching out to us. Here is a link that will help you connect your soundbar to your TV. Thank you.
