- Mute
10-21-2022
06:31 AM
(Last edited
10-24-2022
05:44 PM
by
SamsungJoJo
) in
Hi,
Hopefully this is in the correct place.
Galaxy A50 does not sync when power save is switched on, or at least the calendar app says it does not.
If I go into the Battery app and switch the "Power saving" on, then load the Calendar app and try to Sync it manually "Sync now" I'm told "Can't sync calendars while Power saving mode is on."
Is there a way round this as I'd like my calendars to be upto date but always want to save as much power.
Thanks in advance
Solved! Go to Solution.
- Tags:
- A50
- power save
- Mute
10-21-2022 07:57 AM in
Other Mobile DevicesThat's impossible
Because when you turn on power save mode the syncing in the background will turned off
- Mute
