A52 Battery drain
(Topic created on: 4/14/21 5:40 PM)
Jendee
Other Mobile Devices
I just bought the A52 phone, and its battery is draining quickly.  I had the A51, and had to return it because the motherboard was damaged. Do all A series phones have problems? I never had problems with my J7 Star.
SamsungCole
At this time it is recommended to send the error log report for this issue under the Member's app. Here are some steps for the log reporting:
1.      Download Samsung members app from Galaxy store (If not already downloaded)
2.      Open Samsung members app -> log-in with Samsung account -> Explore -> press “+”sign
xTreex
I've had the A50 for over a year with no problems.
Sami30
Halo
Some apps and games will drain your battery but if it continues to do that I say return it.
submit an error report via samsung members app
ScreamingCargo
I agree. I just got the samsung a52 5g when it came out last week and I only actively use it for 1 hour and 30 minutes and the battery is at 50%
SamsungCole
