Highlighted
Battery issue on Samsung A71 5G
My samsung a71 5g device battery  draining very fast, when I use the mobile data. Need a solution
1 REPLY 1
Highlighted
Cosmic Ray
Re: Battery issue on Samsung A71 5G
I'd try this....
In settings, go to "Device Care" and hit the optimize button.  You can also just click the battery are under Device Care, and confirm that your power mode is optimized and look for an app that is hogging your battery.  My bet - you have a rogue app chewing through your battery.  You might just need to uninstall.
You might also want to consider a reboot, if the above does not work.  Good luck!
