Bluetooth keyboard compatibility issues with android system
(Topic created: 09-02-2022 05:22 PM)
useru2tLU18TtJ
Other Mobile Devices
Android 12, Samsung Galaxy A425G cell phone.  Satechi Slim X1 Bluetooth Keyboard.
When I turn the external bluetooth keyboard on and off, the app and/or browser tab somehow resets itself, cursor goes to the top of the screen in a note app, browser refreshes, and some apps like facebook act as if they are reloaded or hit the home button.  It actually can take you away from the screen.  It doesn't just switch keyboard from the virtual to the bluetooth.  It's quite annoying to say the least.  Aside from this issue, the keyboard works perfectly otherwise.  It's an annoying issue that I cannot find any solution to.
Also, if I have the keyboard settings set to allow virtual keyboard along with the bluetooth, if I put cursor in the form window to type, and then turn on the keyboard, the virtual keyboard will disappear and then the cursor will jump to the top of the screen, completely off the form entry part it was on.  Again, annoying.
What could be the issue?
1 Reply
lskbs
Si. Eres
