Camera Problem with a10s A107F
(Topic created: 09-09-2022 01:14 AM)
userIFLzYhxB94
Other Mobile Devices
Recently I update my a10s A107F with دانلود رام a10s a107f phone to Android 11, problem is on camera app which when I'm recording video it close automatically after 10sec!
Does any body have the same problem?
should I flashing my phone and try to factory reset?
1 Reply
Jacobbbb
Sun
Yes, the A10 is one of the worst phones from Samsung you can buy.
You should really think about upgrading to the A53 or something.
But with your issue I'd say just factory reset it, no need to flash stock roms onto it. I also think it could be a cache issue so go into app settings and clear it's cache before factory resetting your phone.
