Chromebook Pro - Is there a microphone and where is it and how can i use ?
(Topic created: 04-01-2020 09:38 AM)
notabigdeal
Cosmic Ray
Other Mobile Devices
Hi Support
Model is XE510C25. Does this unit have a microphone? Where can i locate it and how can i activate it?
Thanks
NABD
JORTIZ_12
Product Expert
Hi @notabigdeal ,
The mic should be located next to the camera. Please follow the steps below to enable it for use:
Open your Chromebook settings by clicking the gear icon in the system tray. Open the Privacy and security section. Click Site settingsand you'll see a list of individual things that can be changed. Scroll down the list to find Camera or Microphone. If this was useful please select solution and send a like.
Best Regards
JORTIZ_12
Product Expert
Hi @notabigdeal ,
Best Regards
notabigdeal
Cosmic Ray
Hi jortiz
thanks for the help !
NABD
