Disabling M02 battery charging via PC
(Topic created: 10-04-2021 02:01 AM)
user4LLbV8Ri5N
Other Mobile Devices
I just purchased a Samsung M02 phone. What I want to know is, is it possible when I connect my phone to a PC (for an internet connection via USB), although the battery is fully charged, it keeps over-charging. Is there any option that I can stop charging it temporarily?
LongHiker
Samsung Care Ambassador
@user4LLbV8Ri5N This discussion area is for US based products. I don't think that you are going to find an answer to your question here. I suggest that you find a discussion area focused on India for your question.
1 Reply
LongHiker
