Do Not Disturb will ring with allowed contacts but doesn't display unless you do several swipes
(Topic created: 04-21-2022 05:33 PM)
bb2020
Other Mobile Devices
samsung dnd with contacts allowed will ring but does NOT display unless you do several swipes. WHAT GOOD IS THAT? Seems more disturbing. LG does this correctly.
Try: Settings> Notifications> Do Not Disturb> Hide Notifications. Make sure to disable Hide Full Screen Notifications when screen is off. Hopefully this will work.
bb2020
thanks!!!!
You're welcome, happy to help. Could you please mark my comment as the solution with the 3 dots next to my comment? It helps others if they have this issue. TYIA
bb2020
sure wiĺl! that setting was really buried deep on the list. thanks again. i have an a53
Who_Dis
Neutron Star
if the above suggestion didn't help, you can also report the issue to samsung using samsung members app > get help > error report   after reproducing the issue
bb2020
thanks it worked!
