Yoseph
- Mute
‎03-23-2021 08:41 PM in
Other Mobile Devices
I realized that after I updated my Samsung Galaxy A50 to the new One Ui 3.1, I started having issues with my screenshots being that screenshots I took were not saved.
Solved! Go to Solution.
imjusther4candy Now
- Mute
‎03-25-2021 07:26 AM in
This is how to get it to work.
Head into settings > advanced features > motions and gestures > palm swipe to capture. Make sure this option is toggled on.Swipe the side of your hand across the display. ...The screen will be captured, flashing and saving in the "screenshots" album/folder in the gallery.
JoycieG
- Mute
‎03-23-2021 08:45 PM in
yes I do too
imjusther4candy Now
- Mute
‎03-25-2021 07:25 AM in
do you ever do that trick where you run your the side of your hand across your screen?
imjusther4candy Now
- Mute
Yoseph
- Mute
‎03-26-2021 01:11 PM in
Thanks for all you help!
