Edge Panel acting up
(Topic created: 04-21-2021 01:43 PM)
RedBarchetta1
Other Mobile Devices
Just had the April security update, now when I try to direct dial a contact on my edge panel, Zoom opens up. Update broke my edge panel functionality. Galaxy s20 FE
garvey88
Having the same problem as well! Did you find a solution?
RedBarchetta1
Just by dumb luck. I went to make a call, but instead of doing it from contacts, I was in a text, I use Textra app, and hit call and it asked me if I wanted dialer or zoom. I selected dialer "always" and had a feeling it might fix it. I checked it and sure enough, it was able to dial from the edge panel again. Hope it works for you
April N
I was having the same issue and also use the Textra app and your steps fixed the issue. Thanks!
RedBarchetta1
Nice!
garvey88
I don't have the Textra app, so I guess that won't work for me
RedBarchetta1
But maybe it will work through your stock text app. Does it allow you call a contact from within the app?
garvey88
Yes
user5TcU3W68BB
I downloaded the app just to fix the problem. It worked and then I just deleted the app. Thanks so much!
