Showing results forΒ
Search instead forΒ
Did you mean:Β
Highlighted
Freezing Problems On A50
after updating May months update i have facing a problem, which is suddenly my phone turn switch off and appearing samsung logo thm 5-10min phone turn on. πŸ˜‘
2 REPLIES 2
Highlighted
Cosmic Ray
Re: Freezing Problems On A50
Hello! maybe there's an app or software that consumed a lot of battery after the update and it could be the possible reason to randomly restart the phone. You can wait for the next software update or get back to the previous version manually by flashing firmware(consumed a lot of time to study), or simply you can just do a factory reset, it will clear all of your saved datas.
Highlighted
should i wait next update πŸ˜‘
