Galaxy A14 connection problem
(Topic created: 10-21-2023 10:04 AM)
Branka
Other Mobile Devices
Hello,
I have Samsung Galaxy SM-A14 (SM-A145R /DSN) It is bought in Croatia. I can't use it anywhere outside Croatia  or Serbia because it is not possible to connect it to any 4G, 3G, 2G network outside this countries.
Does anyone knows if there is any official firmware that is suitable for this phone and which will makes possible to search and connect to any network around the world?
I bought this phone in phone shop and it is not part of any provider subscription.
Thanks in advance!
LongHiker
Legendary Samsung Care Ambassador
@Branka Unfortunately this area is for Samsung US products and services so you probably won't find a solution here. You should post in the discussion area for your geographical area to find someone who could help you out. Check https://www.samsung.com/us/common/visitlocationsite/ for the appropriate location.
LongHiker
Branka
@LongHiker Thank you for suggestion. I will try.
