Galaxy A20 battery Drain
(Topic created: 11-21-2021 07:55 PM)
userT1kpT5gTHC
Other Mobile Devices
Hey so I have a galaxy A20 and it's been having some battery issues. Itll be at like 20% a min later itll say 15 couple mins goes to 10 so on. Also when I plug it in to charge it takes wayyy to long for a phone to charge plugged it in last night woke up in the morning and it was only at 60%. Now today I plugged it in when it was at like 15 and I accidentally pulled it off the charger and it immediately dropped to 10 plugged it in and unplugged it it dropped to 9. Did that several times and each time I plugged it in and unplugged it it would drop another percent. Bad battery?
Niqqers999
:cactus:CACTUS:cactus: :cactus:JACK:cactus:
Do you get the "Fast Charging" notification when you plug your phone to charge?
You can view apps power usage in battery setting tap on power graph there it will list all apps highest usage will be at the top.
MDGS
Go to developer options and check running services and will tell ya the app that's killing your phone.Back up phone ,do cache partition then all resets if needed but could have a bad app & it will be on the top running services
