Bean5669
Galaxy J7 - LED indicator
JUMP TO SOLUTION
I just purchased the Galaxy J7 & it seems the LED indicator does not light up? And there is no setting for its use in notifications either? It doesn't light up while charging & does not light up/blink when notifications are received...am i missing something here? Why would this feature be taken away?? Does it even exist on this phone? Is there an app i can use to rectify?
1 SOLUTION
userWhsYYddfpg
Re: Galaxy J7 - LED indicator
JUMP TO SOLUTION
Go to settings; click accessibility >  hearing > then turn on Flash Notification and that's it.  Your rear flash will blink whenever you receive a call or message.
114 REPLIES 114
Honored Contributor
JUMP TO SOLUTION
Hey there, Bean5669! Please provide us more information about your device.
Can we get the exact model number and Baseband (both under Settings>About Device) for your device as well as your carrier? This will better allow us and the community to assist you both now and in the future!
Kristy-Lynn
JUMP TO SOLUTION
I am havibg the same problem with my SamsungGalaxy J7........
userRPsBWP46ev
JUMP TO SOLUTION
Honored Contributor
JUMP TO SOLUTION
Just wanted to check @userRPsBWP46ev if you were saying that you were experiencing this same thing.
I believe it was mentioned in a previous post that the LED indicator light had been replayed for a front facing flash. But I'll double check for you. Please update if this was not your initial inquiry.
Be sure to click " ✓ Accept as Solution" when you find an answer that works for you. If a post stand out to you, perhaps you could give that post a star to show other community members they were able to assist or was relevant to you.
userfslWSmXVM2
JUMP TO SOLUTION
Helpful
userqAQPt2AxHH
JUMP TO SOLUTION
My J7 pro Led indicator not working
Honored Contributor
JUMP TO SOLUTION
Hey Community! Anyone else seeing this problem? Anyone have a workaround? Let us know!  Smiley Happy
userZZ2wUgYcGI
JUMP TO SOLUTION
Me too. Does it even  have a light  to  indicate charging
userhewxoKcNol
JUMP TO SOLUTION
Galacy j7
