Highlighted
Galaxy J7 Star, 2018 model BATTERY HELP PLEASE
JUMP TO SOLUTION
I fall asleep on the phone with my fiance at times. And sometimes i will play spotify and sometimes both at the same time. I also dont have a samsung brand charging cord. But the box is samsung model adapyive fast charging. So why does my J7 charge so slow overnight. Please help. I know its ine of these issues i need to pin which one. I wake up with my battey at 97% after an 8 hour charge from being around 20%
1 SOLUTION
Highlighted
Re: Galaxy J7 Star, 2018 model BATTERY HELP PLEASE
JUMP TO SOLUTION
Hey there!
We can't confirm the compatibility of Non-Samsung products such as your charging cord, which may be causing the slow charge.
We would recommend using a Certified Samsung Charging cable and USB Fast charging block.
You can locate one for purchase at https://www.samsung.com
2 REPLIES 2
Highlighted
JUMP TO SOLUTION
Hey there!
Highlighted
Why y'all charge 30$ for a charger?🤔
JUMP TO SOLUTION
