userxKB8CI5gYm
Galaxy a70 charging problems
Recently i've been having weird charging problems. I think it started to happen after a recent update a couple weeks ago for the galaxy a70, where i plug in my charger and then the power cuts in and out, then a notification pops up saying my phone is overheating, eventhough its not at all. I've tried to factory reset, make sure all apps are updated, did the coolermaster, cleared cache, did virus check, checked to make sure it wasn't my charging accessories. I'm farirly sure that's its not due to faulty hardware, i've taken good care of my phone. Im really hoping its a software fix of some sort. HELP PLEASE!!!
1 REPLY 1
Re: Galaxy a70 charging problems
Thank you for reaching out. Do you experience these symptoms if you test charging your device in safe mode?
