Green light on top right-hand corner?
(Topic created: 05-12-2022 11:12 PM)
Dutosha
Other Mobile Devices
Dear Samsung,
Could someone help understand what the green light means in the top right hand corner?
Thank you so much in advance
Faith4Hope
Comet
It's to let you know if either your camera or microphone is currently being accessed by an app.
I hope this helps. Please leave a heart to like this reply & mark this as a solution if this helps, thanks. Take care 👋 🙂
1 Reply
Faith4Hope
Comet
