Red Giant
Re: Help me my Samsung Galaxy J7 battery draining fast
JUMP TO SOLUTION
Hey everyone,
We did get some reports in from our other thread where folks have said that taking the battery out for a few moments and then restarting the device before attempting to charge has solved the problem. If you've tried this and are still not able to charge your device above 91% please send me a PM with the following information:
1) Name
2) Full Model Number
3) Carrier
4) Baseband Version
5) IMEI Number
6) Where you bought your device?
7) Where you currently use your device (region wise)?
user4PBMT187vk
JUMP TO SOLUTION
1.Samsung galaxy j7 2016
2.SM J710FN
3.Tim telecom italia
4.J710FXXU4BQL3
5.357125071265544
6.I bought it mediaworl ancona italy
7.I'm using this mobile in Porto recanati marche region
userUVut6yBJbK
JUMP TO SOLUTION
1) Haley Brown
2) SM-J727T1
3) Cricket
4) ??
5) 354254091049499
6) Metro PCS
7) USA Galion, OH 44833
JUMP TO SOLUTION
Have you updated the device recently?
userXNCbBUhYqo
JUMP TO SOLUTION
Was this to my question?
userMu9W2uRp2F
JUMP TO SOLUTION
my j7 did the same thing. then I noticed that the location services had been set to extreme. changed it to low and battery lasted longer. the update changes all settings without telling you.
user8QW00Jilkl
JUMP TO SOLUTION
Go to settings > apps > Google play services > storage > manage storage > CLEAR ALL DATA, restart phone and you are done everything will be normal as before, I was so frustrated of this problem a few days ago, even bought a new battery but nothing changed, called customer support and they asked me to reset my device would solve the problem but I didn't reset my device got lots of important data all I did was reset Google play services app storage  everything is fine now even tested the old battery and it is working fine, just wasted my money by buying the new battery
user4PBMT187vk
JUMP TO SOLUTION
2.SM J710FN
4.J710FXXU4BQL3
5.357125071265544
userpYVRu7NDwX
JUMP TO SOLUTION
Having the same problem. The software update occured a couple of days ago and now the battery can´t stand 3 hours when i had it running for the whole day. Tried to reduce the screen glow and other settings but its still beeing drainned.
Cant understand why this is happening nor do i know if i can trust in samsung in my next purchase.
userXNCbBUhYqo
JUMP TO SOLUTION
So my Samsung J7 is less than 3 months old and has been working fine, until the last update that I allowed to install overnight and now the battery drains even while plugged into my CLA all day. Can I reset the phone back to the it's factory settings? Aind if so, will I lose my contact information and everything else on my phone?
