Sachu
Re: Help me my Samsung Galaxy J7 battery draining fast
JUMP TO SOLUTION
Whats is the solution for this battery draining?
JUMP TO SOLUTION
Could you provide me with the model code for this device?
Sachu
JUMP TO SOLUTION
SM-G611F
JUMP TO SOLUTION
@Sachu; To enable Safe Mode, follow the link below. It will take you to a step by step guide. Let us know if this helps. Thanks!
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=676183&modelname=SM-...
Sachu
JUMP TO SOLUTION
In my phone there is no safe mode is on. And also my battery is draining. Plz give me a solution.
JUMP TO SOLUTION
Give this a shot; Settings>apps>3 vertical dots>Show system apps> Phone (All3)>Storage>Clear Data/Cache
Settings>Apps>Click on the three dots at the top right corner>Show system Apps>Device Maintenance>Storage> Clear Cache
Settings>Apps>Click on the three dots at the top right corner>Show system Apps>Battery>Storage> Clear Cache
JUMP TO SOLUTION
Hello, Just following up to see if you still need any assistance?
Sachu
JUMP TO SOLUTION
Sir . I do all the thing you say. But the battery draining is not stoped. Sir plz make necessary steps.
JUMP TO SOLUTION
Just to double check, when you placed the phone in safe mode, the battery still drained faster than normal?
JUMP TO SOLUTION
Hello @Sachu, Just following up to see if any assistance is needed?
