- Mute
08-28-2022 10:10 AM in
Other Mobile DevicesAlthough I have the A13 5G, I'm assuming that you guys can help me. If not, please re-direct me.
I had the little man set the way I wanted it to be, but, of course, as I try to learn the A13, I **bleep** up what I had wanted. So, please try to get me back to: When clicking the little man, I was able to toggle between two differently contrasted views of the present screen without any small screen being also being opened. After the first screw up, when selecting the LM, I somehow got a small screen that showed two items in it and nothing apparently happened. On the second screw up, when selecting the LM, nothing at all happens; no small screen, no change in anything. I'd like to get back to where selecting the LM, allows me to toggle between differently contrasted screens. Thanks.
Solved! Go to Solution.
- Mute
08-30-2022 07:14 AM in
Other Mobile DevicesOK, I'm now getting somewhere with my quest. Although I can now get the two contrasting screens that I want, there still is a problem. But, first let me show how I get to those screens.
Settings>Accessibility>Visibility Enhancements>Color Correction=ON>Correction Mode (pick 1 of 3 choices)>Options>Color Correction Show (Accessibility Button)=ON.
So, with this setting, when toggling the AB, I now get a subscreen with McAfee, Assistant Menu, and Color Correction. Selecting Color Correction between ON and OFF does toggle the contrasting colors; however, I now need to delete both McAfee and Assistant Menu from the AB subscreen??? Thanks.
- Mute
- Mute
08-30-2022 10:53 AM (Last edited 08-30-2022 10:55 AM ) in
Other Mobile DevicesGot the answer to no subscreen when toggling the AB: Go to Advanced settings in Accessibility, select what functions are available for the accessibility shortcut and the Accessibility Button (AB). When there, from the list of available functions, I unchecked McAfee and Assistant Menu, but left Change Color checked. By only having one item in the AB, the toggle does the color change without showing a submenu. thus, if one doesn't want a submenu, only choose one item for the AB.
