Highlighted
How/Where do I get/order a samsung level over replacement audio cord/cable?
JUMP TO SOLUTION
1 SOLUTION
Highlighted
Honored Contributor
Re: If you are looking for the Samsung brand audio cord usual...
JUMP TO SOLUTION
You can also check on www.samsungparts.com. They can be reached at 800-627-4368 for a more accurate inventory.
2 REPLIES 2
Highlighted
Nebula
JUMP TO SOLUTION
If you are looking for the Samsung brand audio cord usually you can get it over Amazon or Ebay but be careful there might be some fake ones. But you can get a replacement of other brands from Amazon or Best Buys or most electronics shops.
Highlighted
Honored Contributor
JUMP TO SOLUTION
