- Mute
07-17-2022 06:43 AM (Last edited 08-02-2022 01:11 PM by SamsungRyder ) in
Other Mobile DevicesI have a Galaxy A53 5G and when i go into settings then to sound quality and effects there's a button you supposedly you can turn on UHQ? What is UHQ and how do i turn it on? Because everytime i try to turn it on it doesn't do anything.
Solved! Go to Solution.
- Mute
07-17-2022 07:44 AM (Last edited 08-19-2022 07:19 AM by SamsungRei ) in
Other Mobile DevicesIt enables automatically when headphones or an AUX cord is plugged in. UHQ is Ultra High Quality.
- Mute
07-17-2022 07:40 AM in
Other Mobile Devices@Buckeyeman50 After you plug in headphones, you can enable it.
- Mute
- Mute
07-17-2022 08:03 AM in
Other Mobile Devices- Mark as New
- Mute
07-17-2022 08:10 AM in
Other Mobile Devices@Buckeyeman50 "A Galaxy A53 5G doesn't come with a auxiliary plug in. You have to have wireless headphones."
Plug in USB headphones and you can enable it.
- Mute
07-17-2022 08:23 AM in
- Mute
07-17-2022 08:05 AM in
- Mute
07-17-2022 08:33 AM in
Other Mobile DevicesHere is the link for Samsung wired earphones: https://www.samsung.com/ca/audio-sound/others/premium-headset-level-in-ear-black-eo-ig935bbegca/
The link for Type-C to 3.5mm Audio Aux Adapter: https://www.samsung.com/ca/mobile-accessories/usb-c-headset-jack-adapter-ee-uc10juwegca/
- Mute
07-17-2022 10:24 AM in
- Mute
07-19-2022 06:22 PM in
