Is there any other way to power off my phone without using the side button?
(Topic created: 09-30-2021 02:20 PM)
K1m
Other Mobile Devices
Bee18
I used to own a J3 and the only way to power off is through the power key on the right side if your phone. The Power Key is a dedicated Key for Restarting, power off & Emergency
LongHiker
Epic Samsung Care Ambassador
@K1m It helps to know what phone you have.
Swipe down Notification bar twice. You should have power button on top right.
K1m
Thank you so much, I thought as much but I wanted to know if there is any other option apart from the side key.
K1m
@AndreyRassikhin my phone does not have that function. @LongHiker Yes, my phone is a J3.
Bee18
