Highlighted
Lock Screen Problem -Dr. Fone Please help
Phone: Samsung J5:
I inadvertently invoked the Screen Unlock option in the Wondershare Dr. Fone app. I want to go back to the previous state with the normal lock screen. The screen doesn't appear any more which is what the app does. How do I undo the 'Remove phone lock screen' change. It appears to have written to my sim because if I remove the sim the lock screen option behaves as normal.
I assume there must be a file written which I have to identify and erase. Can anybody help me? I really want to reverse this situation. Any advice deeply appreciated. Thanks in advance
2 REPLIES 2
Highlighted
Supernova
Re: Lock Screen Problem -Dr. Fone Please help
@uservZOEOqWUjl have you tried removing that app entirely?
If that doesn't help:
Be sure to click" ✓ Accept as Solution" if you found this reply solved your issue or pointed you in the right direction. You can also click the heart to let me know your appreciation!
Highlighted
Supernova
@uservZOEOqWUjl did this answer your original inquiry?
If so, can you click "Accept as a solution" on the post that helped so that others know the answer here?
Thanks so much!
